How to Rip DVD for iPhone 4S with DVDFab DVD Ripper?
05/27/2020
Although it’s almost the time that Apple announce its iPhone 5S smart phone, the previous S iteration iPhone 4S is still enjoying very hot popularity. This can be easily seen from waves after waves of promotions rolled out by each carrier. There is an unspoken reason behind this -- that is the lowered price tag. Anyway, iPhone 4S is still a great phone, no one tries to deny. So, don’t worry about your iPhone 4S. You are not outdated. This tip below will tell you how to convert DVDs to play on your iPhone 4S, so that you can still make the best out of it. The helping hand here is DVDFab DVD Ripper, the smart and easy-to-use DVD Ripper software.
Follow the step-by-step guide to see how to do it:
Convert DVDs for iPhone 4S: Step 1 -> Download and install the latest DVDFab 9 onto your computer;
Convert DVDs for iPhone 4S: Step 2 -> Launch DVDFab 9, choose Ripper option at the Option Interface (or from the Option Bar at the Main Interface), then load the DVD you are about to convert;
Convert DVDs for iPhone 4S: Step 3 -> Select the movie title, audio track and subtitle stream you want to keep at the Operation Window, click the Profile Box (or Profile Icon) to find iPhone 4S from Profile Library and press "OK" button, then just hit “Start” button at the Main Interface to go converting.
Note: you need the proper profile your iPhone 4S model, as there are several profiles in the built-in Profile Library for different models of iPhone 4S.
Product you need order: DVD Ripper
For more information, just move on to DVDFab DVD Ripper page.
